LIGHTING
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudober, Feb 21, 2002.
  1. mudober
    mudober Registered Member
    Feb 19, 2002
    23
    I currently have a set of Warn SBD210 lights with the high low beam feature.They dont seem bright enought for me.
    Does anyone have them KC- or other brands of rectangled lights& how are they?
    Thanks for your thoughts
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The real KC Daylighters, with the sealed beam bulb that's rated at something like 385,000 candlepower each are bright! They are also not street legal, by any stretch of the imagination. Cibie also makes some monster lights that are very popular with the rally racing crowd.
  3. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    im running fully modded dick cepek super off roaders with 150 watt bulb replacements. I also have a set of JC 6x9 daylighters with 130 watt bulbs. They are bright. its like the sun came on
    </font color=blue>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
    "If First you don't succeed, Destroy all attempts you've tried"
  4. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i run the "real" kc daylighters and they are BRIGHT.
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  5. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    Lightforce all the way, some where around 700,000 candle power!!
    <a target="_blank" href=http://www.bigredjimmy.iwarp.com>http://www.bigredjimmy.iwarp.com</a>
  6. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    I have two KC Day lighters, and They are Way Bright. I can't believe them. They are about $45.00 each though.
    73 3/4 ton Chevy. 383 stroker, TH350, NP 205, 14bolt FF(Detroit), Dana 44(limited Slip), 6in. lift, 36x 14.5 super swampers
  7. Grim-Reaper
    7,385
    Atlanta
    RobZilla has a set of those and I thought they were pretty good. never heard a complaint out of him about them. Maybe the problem is not the lights but the power source.
    Where are you tapped into the electrical system for these buggers? If your tagged at the fuse box then your proably having a voltage drop.
    Where are you ground off of? Ground at the core suports sometimes are not that good. Ground at the frame are not great either unless you have run a new ground strap from battery to either of them.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i like the Pro Comp 8'' 130 watt lights. they are bright and if you get them in black not to expensive.
    also the KD day lighters are nice. i run 4 ov them. 3 in the front ad on in the back. along with my cheap 30 dollar lights from wall amrt on the side i have all the light i need.
    Grant
    take me drunk, i am home
    www.geocities.com/seventy4blazer/parts4sale.html
  9. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Yeah, first I would check your wiring. You want as little wire from the power source and the light itself. Also, are you using a switch supporting all the current? Or are you using a switch to throw a relay?
    I run 4 Procomp 5x7 100s and 2 ProComp 8" 130s. I like them a lot. I have enough lighting for a small town many times! Checked them all last night getting ready for a big run and damn near burned out my g/f's retina! That means they are ready to go!
    I also use a pair of ProComp 100s for side lighting (one on each side) and a pair of 55W ProComp driving lights for reverse. I like the ProComps because of their pricing. And, while most of my lights are new, one set of my 5x7s are 8 years old. Never had the slightest hint of a problem with them!
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
