Lights for the 4x4 shifter case/cover...where??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben, Jun 21, 2004.
  1. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    R&R'd the clutch. Shop did not rehook up the light for the 4x4 plastic housing.
    Now I can't locate the wire. Climbed under the truck and stuck my hand on top of the tranny trying to feel for the wire. No go.
    So tell me...where does the wire come from/connect from before going to the shifter case? Maybe the shop cut the original wire, I don't know. In any event, I'll have to trace it from somewhere, what's/where's the starting point?
    Thanks!
  2. dyeager535
    26,978
    208/241 actually should be run under the carpet. Believe it goes in from the front (towards engine) of the plastic piece. Just runs under it.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Just take it back to whoever did the swap and have them hook it back up since they disconnected it. /forums/images/graemlins/ignore.gif
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    The wires are under the carpet. There is a lead that goes through the floor under the 4x shifter to the top of the T-case. It's only 6-12" long.
