Lights out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MILOLGJC, Oct 10, 2002.
  1. MILOLGJC
    MILOLGJC Registered Member
    Sep 27, 2002
    29
    FL
    My dash lights went out and also ...and maybe unrelated, the water temp gage has ceased operation. I can't seem to locate anything in common with these two components on the electrical diagram in my Haynes manual. Also, I have checked all fuses etc... I am hoping not to take the dash apart. Any ideas? /forums/images/graemlins/smile.gif
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Are your tail lights on?
    usualy when the dash lights go out the tail light fuse has blown.
    The dash lights are are tied into the tail light circuit.
  3. MILOLGJC
    Sep 27, 2002
    29
    FL
    Everthing else works ok...I have checked the fuses and all appears well. I was thinking a loose ground wire maybe, but the rotten wiring diagram I have is not much help. /forums/images/graemlins/confused.gif
  4. dyeager535
    26,978
    Most of the grounds in the cab are plugged into the buss bar on the drivers side behind the dash...not bolted to the firewall or the dash, off to the left between those two...basically the drivers side of the cab front.
  5. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I would guess a bad or dirty rheostat on your headlight switch. If you can fill out your profile and indicate what year we are talking about...it helps us help you.
  6. MILOLGJC
    Sep 27, 2002
    29
    FL
    The vehicle in question is a 1976 K5 Blazer. Thanks for the info.....I'll look behind the dash tomorrow.
  7. dyeager535
    26,978
    Knowing that its a '76, I now don't know if there is a buss bar for the grounds behind the dash panel. (most 80's trucks did) Just a heads up if you decide to look for one.
