lights staying on
Discussion in 'The Garage' started by bowtiewrench, May 6, 2005.
  1. bowtiewrench
    bowtiewrench Registered Member
    Oct 19, 2004
    24
    Woburn, Mass
    Well the recent problem with the k5 is that the tail lights are staying on after shutting it off. I havent had much time to check every thing but the headlight and running light switch seems to work fine, not sure on the break pedal switch. Any of you guys ever run into this problem? obviously something some where is getting jumped over and letting power to the lights. Thanks
    Alex
  2. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    you may have a faulty light switch with an internal short. I dont have a wiring diagram on hand to trace it out.
    You can try pulling the fuse and see if the correct circuit is supplying power to the tail lights.
  3. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Step on the brakes after the truck is shut off and the light switch is off. If they get briter(the brake lights come on) then it would be in the headlight switch, and if they dont get brighter than it would be the brake light switch i would think
  4. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    Usually when I've had this problem in the past, it's been the brakelight switch. Sometimes you can push the pedal down and it will come back and hit the switch right and they'll go out, but come back on again when you go into the house. Had a neighbor with a mercury do that, we replaced the switch and solved the problem. Thier's had actually stayed on so long it melted the harness that plugs into the switch.I'd replace the switch since it's the easiest, and least costly, and try that.Then if they still don't go out then you may have a "bleed over" problem, something's rubbed or got pinched and it's causing current to "bleed over" to the brake lights. Hope this helps,
  5. bowtiewrench
    Oct 19, 2004
    24
    Woburn, Mass
    Thanks for your help guys, Im going to get one tommorow.
    Alex
