Lights wont come ON!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cegusman, Oct 29, 2001.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Last night went wheeling lights worked, just broke chain in transfer case. Today i wash it and tht lights wont come on, I have checked all fuses, Reverse lights work blinkers work just nothing when the headlight switch is pulled. Any ideas?
    Houston, TX
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I would check the dummier switch on the floor. They can go bad without notice. Also check your relays. They can also go bad.
    My .02,
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Where are the relays located? I also dont get any gauge lights or running lights
    Houston, TX <P ID="edit"><FONT class="small">Edited by cegusman on 10/29/01 05:11 PM.</FONT></P>
  4. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    They are located by the fuses. They are siver in color.
  5. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    Check the headlight switch it may have came unplugged. Mine use to till i zip tied the plug to the switch.
    <font color=red>A BIG HAMMER CAN FIX ANYTHING.... </font color=red>[​IMG]
