Lights
Discussion in 'The Garage' started by MrArmyAnt, Nov 2, 2005.
  1. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Might also try Harbor Freight. I have a bunch of utility lightst that I got there that have done well.
  3. MrArmyAnt
    Dec 29, 2004
    662
    anyone had a problem with summit 100amp altrnators? It looks nice, but I don't know how well it will hold. It will be pussing 800 watts for stereo, winch, lights, cb.
  4. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Ive had the Summit black 100 Amp alt for a couple years now.. Works fine.
  5. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    just remember USE RELAYS FOR YOUR LIGHTS!!! or fires can occur....
    good use of relays is to goto a junkyard and find a olds 88... I found a 1989 olds 88 and took the relay pack under the hood... you dont need this one as it is so big but you end up with 16 fuses and 8 relays. Relays are standard and can be bought at any parts store and are waterproof.. so a big plus...
    also on our chevies... without AC 2 bolts actually line up and you can bolt it right on... although it wont be level....
    i am going to clean mine up but here is a shot...
