Limited slip or...
Discussion in 'The Garage' started by mud hungry, Sep 23, 2005.
  1. mud hungry
    mud hungry 1/2 ton status
    Oct 4, 2004
    506
    Haydenville, Massachusetts
    Best limited slip or locker for a dd 97 half ton silverado. This will most likely never see hardcore use if any off road use but looking to add something in the back so that it will hook up with the road better plus help with plowing. Any suggestions?
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Go Detroit!!! Detroit Locker all the way. If you dont want to lock it look at the Eaton "Posi"
  3. mud hungry
    Oct 4, 2004
    506
    How well does the Detroit work for the road. I know that it is awesome off-road locker but doesn't it wear the tires more going around corners if it locks or is it capable in allowing the faster speed of the outside tire without chirping or locking up?
  4. 78 k5
    78 k5 1/2 ton status
    Jul 8, 2004
    261
    Auburn, AL or ATL, Ga
    I don't know if they make one for the 10 bolt but an ARB or any other push button will obviously be the best combo for street/plowing....but who wants to throw that kind of money in a 10 bolt :confused:
  5. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    I had a Detroit in the black of my daily driver 81 Blazer for years. Your OK if yo go easy on the throttle. If you are at a stop and make a 90 degree turn while really geting on it you will hear the tire chirp. And if you accelerate out of the turn you feal it lock up and may have to turn the wheel a little more. You get used to it after a while. So i guess the tires will wear a little faster but prety even seeing how you wil be making left and right turns. But you can feal it lock and unlock tho it isnt drastic...
  6. mud hungry
    Oct 4, 2004
    506
    Has anyone ever used the powertrax no-slip locker how do they work and how WELL do they work?
  7. mud hungry
    Oct 4, 2004
    506
    Detriot and the powertrax are about the same in price what would be a better option for me?
  8. mud hungry
    Oct 4, 2004
    506
    anyone?
  9. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    The Powertrax is OK... Ive heard of 'em holding up with 37's so you should be fine. They are easier to install because you dont need to reset the ring gear. Supposed to be able to install in a couple hours in yer driveway. I know with the earlier/cheaper Lock-Rights you could "FEEL" 'em more than a deroit. But I guess the newer No Slips that are in the $400 range are sopposed to be quieter and less harsh. The Powertrax will save you $$ on install and since you dont have huge tires wont have to worry about stock carrier strength.
    :waytogo:
