limited slip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pjwalters, Aug 19, 2001.
  1. pjwalters
    pjwalters Registered Member
    Jul 30, 2001
    11
    kansas city ks.
    can i put a limited slip from a 10 bolt rear to a ten bolt front axel?
  2. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    LSDs are not designed for front ends. I'm not exactly sure why, but I know for a fact that they don't belong up front.....
    <font color=red>PHOTO ALBUM-</font color=red> <a target="_blank" href=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</a>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  3. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    i had a posi up front and had no problems?
    Hut in the well is goin on in here?
    sun desert offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    LSD dont work that well in the front because they are always engaging and disengaging every time you slightly turn the wheel. they wear out quickly because of this. I would recomend a locker. They last a lot longer.
    86 Blazer 4"lift 35" MTRs locked front, still 1/2 ton axles.Other vehicles 69 Firebird with 525 hp,and a 70 GTO www.geocities.com/modifierperformance<P ID="edit"><FONT class="small">Edited by DesertDueler on 08/19/01 10:09 PM.</FONT></P>
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I am putting one up front in mine next weekend.......Dan
    If it ain't broke.......Don't fix it....
  6. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I have an Auburn Pro in my front..makes a big difference in mud, which is about all we have around here.....I don't run it on pavement with hubs engaged, so the locking/unlocking thing is not a factor.....I also have the Pro in my rear...no probs....I don't need a locker for the types of wheelin' I do...Lockers are harder on your parts on the street.....just depends on how you use your truck.....if I lived in rock country, I may consider Tonners and Lockers a necessity.....
    Stuck?...Hell no..I still got some gas left..
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Stay away from a True Trac in the front. My brothers is constantly unlocking when you really need it!
    Mike
    <font color=green>"It's like a sore dick deal, You cant beat it!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  8. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I call them "limited grips", not limited slips!! [​IMG] Go with a locker if you are going to do it!
  9. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Yes, you can YRWV(your results will vary).
    Good luck
