limited slip
Discussion in 'The Garage' started by motorheadnelson, Feb 2, 2003.
  1. motorheadnelson
    motorheadnelson Registered Member
    Aug 12, 2001
    80
    Fort Mohave AZ
    I want to yank the lock-right and put a limited slip in the ol' 12 bolt. Looking at the Auburn Gear, the heavy duty Auburn, Eaton..Any input on these or others? Truck sees mostly street duty, daily driver. Does Detroit make a similar unit? Leaning towards the heavy duty Auburn. Stll want it to hook pretty good. Thanks
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    What size tires are you running? It you have 35s or smaller, I would say an auburn pro series. I have had real good luck with them, especially in my race car.
    BTW I will take that old lockright from you. I blew up the mini spool in my 12 bolt, and need something to get it going again /forums/images/graemlins/wink.gif
    Dan /forums/images/graemlins/burb.gif
  3. motorheadnelson
    Aug 12, 2001
    80
    Fort Mohave AZ
    I'm running 35's, 4.10 gears with a 454/350T. I saw the Detroit Tru Trac, looks like a medium duty unit. How are the street manners of the Pro series? I want to get away from the locker because of the way it steers the truck. Looking for open diff handling. I want to keep the locker, though..put the carrier, bearings and shims away just in case I want to drop it back in, ya know..Thanks
  4. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I have seen good results from both the HD Auburn and the 800lbs. pre-load Eaton . Street manners are very good with clutch groan and slight tire slip on occasion. I would lean towards the Eaton due to the rebuild ability .
    Tom
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I had an Auburn in my 10 bolt, and it worked pretty well. I liked it for street and occasional offroad use. It had great street manner. The only time you knew it was there was if you got on the gas hard around a corner and the inside tire would start to chirp.
    Nothing beats lockers for the trail though. I learned that last night.
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have used the auburn heavy duty units in some street cars. Had good luck with them. I like the way the carrier splits. makes rebuild easy. Only problem I ever had was once the carrier bolts backed out. They warrantied it. and life was good agian. Much stronger than any stock carrier.
