limiting straps
Discussion in 'The Garage' started by 55Willy, May 28, 2004.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I know superlift has em, and I found some on ebay from a VW buggy dealer. I have some spongy ford springs and running DT's for shocks and I'm looking at getting some starps to keep then together. I was wondering who here is running them and do you run one in the rear or one per shock? I'm thinking of one per corner to keep the shocks from hyperextending.
    -Jeremy
    also is $90 for 4 shipped extreme for a 34" strap?
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    The price sounds good, especially for that long of one. And yes one per corner. Make sure they bottom out about a 1/2" before your shock does to keep it alive.
  3. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    also what about getting them a 1/2" shorter then the shock and mounting it to the shock bolts?? vs. the spring plate frame rail mounting tabs??
  4. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Thats what I plan on doing and thats what I see as the most commonly done. Should work just fine.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    As long as we're talking about mounts stronger than factory. The factory stuff tends to rip off when the shock bottoms or tops repeatedly. Same thing with a limit strap other than the strap wouldn't shock quite as bad. I know Jeremy has replaced his, but just throwing that out for the masses...
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    After going back to oregon this past wekeend and being able to crawl around the wagon I'm thinking of:
    on the rear mounting them on the shocks, the lower mount is on the spring plate the upper mount is a hoop that Greg72 bent up for me. that is bolted tot he frame and is hooked together to the other side.
    the front I will go off the spring plates and make a mount on the engine crossmember for the upper. I was gonna do the shocks on the front but I don't want the tire to grab them.
