Limiting travel on your steering ram?
Discussion in 'The Garage' started by Esteban86K5, Mar 15, 2004.
  1. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    O.K. I just finished doing High Steer on my dana 60 and with the tie rod closer to the center of the axle, I have less travel from lock to lock. It only gives me about 5 inches and my ram has 8 inches. SO my question is how do I limit the travel on the ram? I am waiting for a call back from Matt at WTOR but thought I'd post here to get some other opinions.
    One seuggestion that was given to me was to get a peice of 1" delrin plastic and drill the inside hole to the size of the shaft, cut it to lenght, and put it inside and outto limit the travel. Any thoughts on that?
    Thanks for you help in advance. /forums/images/graemlins/waytogo.gif
  2. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    Don't use plastic, a hyd ram will crush it easly. They make hyd ram limiting spacers, go to any place that caries hyd cylinders and they can get you some cheep. I think the ones I ordered a month ago at work were 15-20$
  3. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Right on on the limiting block. You could even have a machine shop cut it down to exactly the size needed.
  4. Esteban86K5
    3,712
    Bakersfield, CA
    I spoke to Matt at WTOR and he said the same thing. Don't use the plastic just use steel for it. /forums/images/graemlins/waytogo.gif
    Thanks guys!
