Lincoln 135 Question
Discussion in 'The Tool Shed' started by stockk5, Jun 13, 2006.
  1. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    Hey, i have a lincoln 135 welder i got 2 years ago, been using it a bunch, worked great. I let my friend borrow it, he was welding some c-notch stuff into his frame for airbags.. yes i know not the best choice of welder, he is gonna go over it w/ another one. Anyways, he was just about done w/ it but now every time he pulls the trigger the wire gets burned up and snaps right near the rollers inside the actual welder itself. Any clue what could cause this? how to fix it? :doah:
  2. botboy
    botboy 1/2 ton status
    Aug 11, 2004
    225
    Delano, MN, USA
    Pull the gun out at the welder, pull all the wire out, blow it out for a few minutes with an air blow-gun, shavings/rust/dirt/dust in the liner can cause such problems.
  3. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    really? so like maybe the dust metal shavings are causing a short or sumthing where the wire is getting pulled through hmmm i will have to try that!
  4. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    bot boy gave you great advice..
    burnback can happen for several reasons.. too high an amperage (trust me that isnt happening on a 135)... internal defects ( that might be happening).. poor maintenance is possible.. so bot boys suggestions are correct
  5. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    I have probably the same welder as you, SP135 right? anyway when I swap out liners for AL, you would be amazed how much junk is in there. I take really good care of my stuff, and it still gets dirty, but I have never had the problem you are speaking of. I would also check the cables at the polarity terminals to make sure they are secure, and not arcing over to the rollers, possibly one is frayed or something down in that area.
