lincoln lockers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudddog91, Feb 25, 2001.
  1. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Hey guys,i dont have a blazer but i do have a 74 3/4 ton.Im almost done putting everything together and am wondering if my frontend will hold up.I built a healthy 383 stroker for it and am running the sm465/np2o5 setup with 4.10:1 gears in the 14 bolt FF and dana 44 8 lug.Its got a detroit in the rear and i lincoln locked(welded) the front dana 44.Has anyone had experience with a welded diff in the front?Its got lockout hubs so street driving will be tolerable,and its not an everyday driver,plus cant you just unlock 1 hub when the going is easy?
  2. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Hey, the fun part of this is you already welded it right, so you can tell us how it works. What size tires? Anything over 35, and good wheelin', you will need to lock both, so the one hub thing doen't really apply, thus you loose the purpose of the welded diff anyway. I know from some experience that if you have any larger than 35's and do some hard wheelin, and didn't put moly shafts in, they will break eventually. I just got my Dana 60 after breakin a 44, which was after the 10 bolt. My knew project has been in my possession for about a year now, and only minor mods, but I have a shop full of heavy parts. This one I intend to do all at once, and right the first time. RIght the first time means nothin less than a 60 up front. Good luck though, and to be completely honest, breakin' stuff on your rig is the best way to learn and learn quick, so have fun.
    Joel
    If you ain't hurt, you ain't playin' hard enough.
    The General
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I think it will mostly depend on what size tires you have and what type of driver you are. If you have modest size tires (36" or smaller) and don't try to blast through obstacles, the 44 can survive. I really don't think a lincoln locker puts any more stress on it than something like a Detroit. For only locking one hub in, this should help turning but be careful if you do get into any type of obstacles. With both hubs locked in the torque is split equally between the two front shafts, with only one hub locked only one shaft is taking all of the torque. I think if you got the one tire which was locked in wedged in a rut or against a rock, it would be pretty vulnerable to breaking.
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    How did you do it? Exactly where did you weld? I am thinking about the same thing as I run 33's and am very light on the throttle. Thanks for the help.
  5. mudddog91
    Dec 28, 2000
    471
    north carolina
    WELL IM RUNNING 38'S,SO.............ALSO IS IT GOING TO BE THE SHAFTS THAT SNAP FIRST OR WILL I HAVE PROBLEMS WITH THE CARRIER OR RING AND PINION?ID LIKE TO KNOW WHICH SPARES I NEED TO TAKE WITH ME!!!!!
  6. mudddog91
    Dec 28, 2000
    471
    north carolina
    TO LINCOLN LOCK YOUR DIFF YOU NEED TO WELD THE SIDE GEARS TO THE SPIDER GEARS AND ALSO WELD THE SIDE GEARS TO THE CARRIER,IF YOU JUST WELD THE GEARS TOGETHER IVE HEARD THAT THEY ARE MORE PRONE TO BREAKAGE.SO YOU SHOULD HAVE 8 WELD POSITIONS ON THE GEARS(4 ON EACH SIDE WHERE THEY MEET) AND 4 POSITIONS ON THE CARRIER(2 ON EACH SIDE WHERE THE SIDE GEARS TOUCH THE CARRIER)
  7. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Hey man, watch the CAPS [​IMG] hurts thy eyes
  8. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Typically either the shafts for the axle u-joints will go first. If a u-joint breaks it usually destroys the yokes on the shafts. I would recommend carrying a complete set of front shafts with the u-joints installed, this saves a lot of time if you have to do a repair on the trail. Another thing that can happen when a u-joint breaks is that it will distort the yokes to the point they will not fit through the hole in the knuckle, meaning that the whole knuckle might have to be disassembled, unless you have a torch to cut the shaft off.
