lincoln pro-mig 135 welder???
Discussion in 'The Garage' started by 85mudblazin, Apr 29, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am new to welding and I have been looking at the pro-mig 135 welder does anybody use it or have heard good or bad things about it? It does have a short duty cycle but I dont plan on using it for long periods of time. I want to make bumpers and do light fabrication work and it is supposed to weld 5/16" so it sounds ok. Thanks
  2. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
  3. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    The short duty cycle will piss you off once you get into larger , heavier projects
    I would try to get the largest machine you can afford , and run power to (220)
    This is the exp. I have had with welders /forums/images/graemlins/thumb.gif
  4. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I have a lincoln 135 and it's a great little box, but if you want to weld with gas on heavier than .125 thick, get bigger machine. Personally, I like flux core, a little annoying if you don't have a wire brush grinder handy, but you can weld thick on 110v
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I'm with RJ! If you are consistently doing thicker metal, get a bigger welder. I have the Lincoln SP-135plus and it is GREAT for the stuff I do which is mostly thin stuff like exhaust and body panels. I plan on getting a Lincoln PowerMig 255 as soon as I get my Federal tax return.
    Chris
