Line lock wont release, why?
Discussion in 'The Garage' started by great scott, Mar 1, 2003.
  1. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    I just finnished installing a used line lock that I got from a freind who has not used it for years /forums/images/graemlins/thumb.gif. It came with no instructions but on one end it reads inlet the other reads out let. I hooked it up with the line from the master cyl going to the inlet(is that correct) wireing was easy as it grounds through the case, so I only had to add a switched power to lock it up.Then I bled the brakes, pumped up the pedle flip the switch,did a burn out /forums/images/graemlins/cool.gif(stupid but fun)and now I cant get it to release short of cracking a brake line open. Any ideas? /forums/images/graemlins/1zhelp.gif
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Surely you turned the switch off even though you don't mention it ?
    LOL
    My guess is that there is a reason why it was free.....
    I'd take it apart, you'll probably find the pintle is sticking in the closed position due to corrosion.
  3. great scott
    Dec 31, 2002
    333
    Utah
    Well it's working fine now. I had to open the bleeder valve on the calipers to release it the first time but now it holds and releases every time. maybe I just needed a break, Ive been working on White Trash(Blazer) all day. I dont think I was so burned out that I left the switch on, who knows. /forums/images/graemlins/tongue.gif
  4. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Bueno.
