Line Locks?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ecameron87, Jun 16, 2005.
  1. ecameron87
    ecameron87 1/2 ton status
    Nov 9, 2002
    115
    AZ, Tucson
    I do not have e-brakes and I am starting to feel very uncomfortable leaving my vehicle on hills especially while off road. The PO ripped the emergency brakes out completely. Has anyone tried using line locks? Are they reliable, and can I use it for an emergency brake?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I use www.mico.com Lever-Lock
    Here is a pic:
    Line locks are not to be used for extended periods of time as hydrolic line pressure fades out in time. I tested mine and it held over night just fine. But I would emagine in time the caliper seals would fail ealry if used all the time like an e-bake would be used when parked. The levr-lock I use has a low pressure warning switch that can be connected to a buzzer or light to warn you the hydrolic pressue is fading out.
    Hope this helps
    Burt
  3. ecameron87
    Nov 9, 2002
    115
    AZ, Tucson
    So do you use this just in moderation while out on the trail, or for other reasons? The PO did a rear disk conversion and didn't install calipers that had a parking brake to it. Would it be better for me to just replace the calipers?
  4. Burt4x4
    6,854
    Well if you want to use a parking brake for extened periods of time then yes I would find a way to get a cable actuated parking brake.
    I use my line lock all the time, even running into the store or while sitting on hte trail takin a brake, but the most important function is when I am in a tree footed situation on the trail. Like stoping on a steep hill, I set the brake and now my feet are free to work the throttle and clutch, one hand on the steering wheel and the other on the lever-lock...1..2..3...GO hahahaa
  5. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    how much did that cost you and was it easy to install?
  6. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    You could install a drive line disk brake that would be cable actuated.
    I still need to bolt up the caliper but you get the idea.
  7. 1967k10
    1967k10 1/2 ton status
    Nov 21, 2005
    1,728
    Nebraska looking for D60's
    Does someone sell a kit for that driveline brake?
  8. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    Yep, a couple vendors here do.
    That one is from High Angle Drive line
  9. 1967k10
    Nov 21, 2005
    1,728
    You mean Jesse right?
  10. ecameron87
    Nov 9, 2002
    115
    AZ, Tucson
    I don't mean to bring up an old post like this, but does anyone know another company other than HighAngleDriveline that has a Diveline E-brake kit?
    It looks like with the HighAngle's setup, I would need to change my rear driveshaft to a CV unit.
