Line-x on an mdf enclosure?
Discussion in 'Audio' started by k5james, Apr 11, 2005.
  1. k5james
    k5james 1/2 ton status
    Feb 25, 2004
    792
    San Diego, CA
    Is it safe to Line-x an mdf enclosure? I'm leaning towards Line-xing the tub of my blazer and I'd like to Line-x the enclosures I got from Greg to match the tub.
  2. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    My uncle bed lined a few Washburn speaker cabinets and they looked pretty nice. Cant tell you if it changed the sound but its doable.
    Later
  3. bigblazer433
    bigblazer433 Registered Member
    Jul 29, 2002
    38
    El Reno Oklahoma
    I rhino lined an mdf box and it worked great and looked great too
  4. AudioMaster
    AudioMaster Registered Member
    Jul 26, 2002
    28
    Southern Utah
    Nothing wrong with lining the box. I've done it to a few of my PA cabs and my old box for my 15 so I wouldn't have to worry about it getting wet.
  5. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    Are you doing the real line-x yourself or an offbrand? how much does it cost for the setup to do it? how much air do you need?
  6. k5james
    Feb 25, 2004
    792
    San Diego, CA
    I was going to have them line-x'd by a real place.
  7. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    It wont hurt. If anything, it will help deaden the box a bit more, even if only slightly. Just remember to tape off the ring of surface area that the speaker will mount to.
    We'll of course need some pics. :D
  8. MrArmyAnt
    Dec 29, 2004
    662
    I'm bed lining my storage/sub solution. It does help to ad density to the box. Make sure it's sealed from the inside though, some wierd people seal the outside and who knows how that line-x will effect any sort of sealing caulk.
  9. Uncle Fester
    Uncle Fester 1/2 ton status
    Mar 23, 2006
    229
    Cheyenne
    Line-x
    I am looking into the cost of becoming a Line-X dealer, and one of the uses they suggest is sub woofer boxs..so there will be no problem at all, just make sure your box is atleast 3/4" MDF.
  10. MrArmyAnt
    Dec 29, 2004
    662
    All sub boxes should be at least 3/4"s inch to begin with for sound purposes.
  11. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Before we get carried away here, it should be noted that a sub box does not require any sort of lining material to deaden it. A properly built box will be of sufficient thickness and have adequate bracing so as to not flex, regardless of the covering material. Ive seen a couple bed liner companies advertise this use, as if it will really help performance. If it helps your sub system's performance a noticeable amount, the box was screwed up to begin with. ;) Ive even seen a few sound deadener companies advertise this use, its bunk. If you want to line it to match your interior etc, sure its fine, it wont hurt. But don't start thinking its necessary, or some super secret trick you know to gain performance, cuz its not. :) The only reason I even mentioned that it -might- help performance in my first response was to reinforce the idea that it wont hurt anything to use it.
  12. MrArmyAnt
    Dec 29, 2004
    662
    ^I agree. Now if your subs are really hard hitting and the resonance of the box is to high, you can lower it with a resin/lead shot mixture on the inside. ads weight and density = lower resonance. but bedliner mostly just looks better :)
  13. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    If your box is flexing (vibrating), its not properly braced, the walls are too thin, or you aren't using mdf/equivalent. A box with the right bracing should not require any artificial mass loading. And this is coming from a guy who concretes his vehicles, so you know Im not biased against mass loaders, they just need to be utilized where they are needed and not where they are not. :)
    But adding lead shot to resin is an interesting mass-loading idea ArmyAnt. Im always looking for new/cheap/interesting ways to sound deaden and mass load, that's another one I'll have to try out. :D
    edit: Oh and always be sure to mount your box rigid to the vehicle's sheet metal. This gives maximum transference of acoustical energy to the chassis (those low lows) while minimizing alien vibrations from box hop.
  14. 1crzy88
    1crzy88 1/2 ton status
    Sep 7, 2004
    119
    NOR Cal
    my whole interior is lixe-xed, my dash with a 15" LCD tv, doors, kicks, and soon to be my custom rear pannels with 2-10's and an amp on each side. have at it. Kind of hard to keep the dust off of though. you can do a search and find some stuff ive sold on here.(door pannels)
    T
  15. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,090
    489
    Grand Rapids area
    If Line-X is going to affect the performance of the box, it means you are putting it on the inside.
  16. MrArmyAnt
    Dec 29, 2004
    662
    Not so. Increasing mass on the inside or outside still effects the overall mass.
  17. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Like I said before, if you need to use Line-X (or similar mat'l) on your box, you screwed up the design/build of the box in the first place. Generally speaking, a speaker enclosure should not require any additional mass loading. Period.
    Don't fall into the all-to-common misconception that enclosure interiors need some sort of spray-on material to dampen, absorb sound waves, reflect them, or anything else along those lines. If you want to follow the idea that sound waves inside the box need manipulating, just throw some polyfil in the box (1lb per cu ft) and be done with it. There's plenty of info on polyfil and how it works if you want to google it. But, if your box is already properly sealed and braced (when necessary), adding a coating to the box's interior will make no audible change in performance. Waste of time.
