link suspension
Discussion in 'The Garage' started by lizard, May 12, 2002.
  1. lizard
    lizard 1/2 ton status
    May 11, 2002
    114
    Tallahassee, Florida
    I have a 1972 Jimmy with D44HD / 14FF with some really nasty-stiff leaf springs and am looking to convert to a long travel coil over suspension for a better ride and more flex. Since the rear end should be much easier I have decided to tackle the front first and once I get that right I will probably switch to a D60 and 3-link in the back to save some weight. All the suspension design info I have found is for roundy round and azzfault racing but I'm not having much luck on the big travel coil over stuff.
    So far I figure I want to use a lower control arm length that is close to the length of the driveshaft so I dont get too much slip joint movement. From there I guess I should try to get the geometry so the caster doesn't move to much through the majority of the suspension travel... at the same time I want to keep the pinion pointed at the CV joint. There has to be a balance/compromise in there somewhere.
    I'm on the east coast and there aren't lots of guys doing this type of work that I can ask. Anyone have some suggestions and / or links to sites that deal with this stuff?? I am experienced welder and fabrication is no problem but I'd like to get it as close to correct as possible for a first timer :-)
    Any help you guys can provide is much appreciated!
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
  4. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
  5. lizard
    May 11, 2002
    114
    hey thanks for the links!
