Links and input on 383s
Discussion in 'The Garage' started by Fubeca, Jan 12, 2004.
  1. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Well I did a search, but not much has been said in the last 9 weeks. I am looking for information on good 383 kits and how to modify the stock TBI system ('91 k5) to handle fuel delivery needs. I am also interested to know what kind of gas mileage to expect. Any links or info would be great /forums/images/graemlins/1zhelp.gif
  2. sandy78
    sandy78 Registered Member
    Nov 28, 2002
    84
    Utah
    John Lingenfelter has a pretty good book on SBC which should help you a lot. I used an outfit called Speedomotive for my rotating assembly and was happy with their work. You can also get rotating assemblies from Summit or Scoggin-Dickey and many others. The big thing is to choose a piston that gives you a compression ratio you can live with. You will also need some machine work. If you are going to invest in the project, I would recommend align-honing the mains, bore and hone the cylinders, and deck the block. You will also want to consider the induction side -- manifold, heads, etc. I don't know much about that in relation to the TBI, but the above mentioned book may help get you started. Mileage will probably drop a little if you don't go to wild or change your driving habits. Anyway, if you have component/mechanical questions, let me know. Good luck.
  3. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Remember to do your grinding/clearancing BEFORE you balance! Also, purchase a small base circle cam so there will not likely be rod to cam interference.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Well I did a search, but not much has been said in the last 9 weeks. /forums/images/graemlins/1zhelp.gif
    If you want to do another search, click on the blank space on the drop down and you can go back a year or four! /forums/images/graemlins/thumb.gif
  5. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Yeah, I think Steve was tweakin' something at the time because there wasn't a drop down box when I was trying to search -- just weeks no other option.
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Mark, I can help you on the technical side of building a 383, clearancing, etc. I did not use a kit to build my 388. None of them had the exact components that I wanted. If you want to know what components are in mine, I can send you an Excel file listing them. /forums/images/graemlins/thumb.gif
    I don't have any experience modifying FI....but I wish I did. /forums/images/graemlins/crazy.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  7. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    Can I get a copy of the Excel file??? Please send it to Blackdog714@ar15.com. Thank you!
  8. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Ben,
    I figured you would know about that end. I'll have to do some research on the injection stuff. I am hoping my current 5.7 will last at least 10,000 more miles so this will be a project I start after I move out to MN. I'd like to see your spreadsheet -- mark@dfcanyon.com .
  9. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Mark & Joshua......e-mails sent. /forums/images/graemlins/thumb.gif
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
  11. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    may i get a copy as well please.
    thanks
    Bournegw@yuma.usmc.mil
    Grant
    Sent! /forums/images/graemlins/thumb.gif
  12. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    go ahead and add me too. I have an idea I think but I am sure you have more experience
    clyons@d11.uscg.mil
  13. cj7jeep81
    cj7jeep81 1/2 ton status
    Feb 17, 2003
    110
    Indiana
  14. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Ben,
    Let me know, if you want I can make the spreadsheet available online and post a link so you don't have to work so hard. /forums/images/graemlins/grin.gif
    You seem to have developed some interest. /forums/images/graemlins/thumb.gif
  15. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Christopher and cj7.....e-mails sent! /forums/images/graemlins/thumb.gif
  16. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Ben,
    Sounds fine to me, Mark. Go for it! /forums/images/graemlins/thumb.gif
  17. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    For the TBI.Talk to Turbo city.I think the guy's name you need to talk to is Tom Miller. He built a 383/vortec using a 454 TB. They have all the stuff you need including the custom chip. Talk to them first before you build the engine.
    They can help you with cam choice, Compression ratio, ect,
    You are more limited in choices with TBI than a carb.
  18. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Anyone who wants Ben's well done excel spreadsheet just download it here.
    Spreadsheet
