Linux nerds
Discussion in 'The Lounge' started by BranndonC, Sep 21, 2006.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    I don't really care for windows much anymore, lots of problems. If I install linux can I use all of my windows programs or do I have to reinstall everything?
    Is linux 100% windows software compatable? Will the no name software I have work? Can I just install it over windows, or do I need a fresh install?
  2. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    No.
    Yes.
    No.
    No.
    Kind of.
  3. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Get a Mac. The new ones (intel) will run all your programs.
  4. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
  5. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,023
    849
    Pinckney, MI
    you can switch to ubuntu or any Deb based linux system(really easy) then you can install Automatix and then automatix will install wine(program that emulates windows) Most windows programs run on it but they are a little slower then normal. Alot of the linux distros come with alot of the excess programs that you would have to buy if it were windows(office etc). I would stay away from any source based linux distros until you are familiar with it. The only thing I really use windows for is video editing, everything else I can do in Linux
  6. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    Linux + openoffice.org should cover about 95% of what you need a PC to do.
    for all the other crap you need winblows for, run XP in a virtual machine. VMWare probably the best & most feature rich. there are open source alternatives out now however.
    If you're a gamer, look up www.cedega.com. i think they're renamed it recently to something else.
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    I have special real estate software that might need windows to run, that's why I'm asking
  8. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    The VMWare app will allow you to run windows as if it were natively installed on physical hardware. it basically fakes out the OS and as far as it knows, it's on a peice of hardware when in reality it's virtual. Really slick peice of software. MS has something similar called VirtualPC.
    That way, you get the benefits of your favorite linux distro for most of what you need but those pesky windows only apps can have an environment of their own. performance is pretty close to native unless you're trying to run something like autocad...
