List of little things to finish up my Jimmy before Memorial Day
Discussion in 'Pacific Region' started by kennyw, May 13, 2006.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Harmonic balancer for a 350 V8
    45 degree oil sending unit fitting found at the back of a small block chevy intake manifold
    Hydro clutch slave cylinder and pressure hose
    NP205 shifter for 32 spline version SM465/NP205 (mine hits the hole in the floor and looks like someone heated and bent it out of shape at some point)
    Adjustable proportioning valve for rear disc brakes on 14FF
    Radiator overflow and cap for '85 GMC Jimmy
    Qty 16 9/16" lug nuts, prefer long chrome style to match the front
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    At least it's all low buck for ya.. :wink1:
    Here's a rough outline I came up with a couple weeks ago to have done by the end of the summer... Shouldn't be an issue now that I'm making some coin again...
    1 - alum radiator $270
    2 - floor steel & seats $100 & $400 = $500
    3 - headers, y-pipe, hi-flow cat, muffler, install $450 & $350 =$800
    4 - fender, wheelwell, sec. battery tray, $200
    battery switch, bulkhead connectors, relays, circuit breakers, $150
    composite for electronic box, rear side panels and custom fan shroud $120 =$470
    5 - flip, shackles $220, frt springs $250, frt shackles $75, brake lines $100 = $645
    6 - tires, rims $1200
    7 - 200 amp alternator $250
    8 - 1 ton difs, Ebay potential, total = god only knows... :haha:
    ...... sealed composite underhood electric box config.....
    battery switch, 2 relays and breakers for headlights,
    2 fan relays 1 breaker, 1 pos & 1 neg bulkhead connector
    (future consideration - battery isolator & welding output...)
  3. kennyw
    Jun 9, 2002
    13,224
    94
    Luckily I hoarded most of the big parts I needed last summer when I was making good money... put it all together in the last 2-3 weeks once I found a place to start working on it. 3/4 ton axles, swap in a new motor without a snapped crank, swapped the 700R4/NP208 for a SM465/NP205, put my nearly new tires off my old 3/4 ton tow rig on it for now...
    now I need to have front and rear drivelines shortened, hook up the wiring to the motor, install radiator and hoses, finish stripping interior and laying down some herculiner (but that may wait till after memorial day), install CB and CD changer. Install all the little misc parts...
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I just discovered I have to start replacing the frame rivets (with Grade 8 bolts, of course). Ranks right up there with taking-out the trash.:doah:
  5. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Hey Kenny, I have the q-jet bracket if you need one. How about 10.00 shipped.
  6. kennyw
    Jun 9, 2002
    13,224
    94
    That will work for me... PM coming your way in a minute.
  7. kennyw
    Jun 9, 2002
    13,224
    94
    ttt updated
  8. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Bracket on the way. :D
