little advice on my 14bff
Discussion in 'The Garage' started by mightywhitey_k5, Feb 22, 2005.
  1. mightywhitey_k5
    mightywhitey_k5 Registered Member
    Sep 3, 2004
    74
    Man i F'ed up this time. Before i had a clue as to what i was doing i removed the main caps on my 14bff, now i have no clue as to which on is r from l not to mention top from bottom. any one out there mess this up as bad as i did and found a way to put humpty dumpty back together again :confused:
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    look at the housing where the caps sit and you will see the marking of where they sat, you just have to look at them carefully and see where each mark is compared to the cap, if all else fails you will have to get a dial indicator and make sure every thing is good.
    What were you doing that you had to take the caps off?? lockers? gears??
  3. mightywhitey_k5
    Sep 3, 2004
    74
    ya thanks thats what i figured i would need to do. and to answer your Q: both 4.88 gears and still havent decided on what type of locker i am going to go with but i am pretty sure it will be dertoit.
  4. mightywhitey_k5
    Sep 3, 2004
    74
    i just noticed u went with 4.88 how do u like them with your 35"s. i will be running 38" i have read that they will still give me plenty of tork and power. are u running a locker in the 14b and did u instal them your self.
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yup got 4.88's with 35's, I like it with the OD tranny, plenty of git up and go, and I installed it all my self.
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Heres how you check left from right. Put the cap on and FEEL the inside where it mates the housing, and see if its smooth or not. Youll be able to tell, if it isnt smooth then try the other cap, if it is smooth, then thats where it goes. Does that make sense?
    Here how they should look.
  7. mightywhitey_k5
    Sep 3, 2004
    74
    ya perfect cence thanks.
