little help please
Discussion in '1982-Present GM Diesel' started by MUDNUTT, Aug 17, 2002.
  1. MUDNUTT
    MUDNUTT 1/2 ton status
    Aug 1, 2001
    339
    Mn
    just picked up a 94 6.5t long block for cheap. having the heads rebuilt and sleeved right now and as cash allows will rebuild the rest of the block. i'm looking to pull the gasser and put it in my blazer. what i need to know is what are all the parts i need to do the swap.
    deck
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    OK, I'll start:
    1. Glow plug controller (I've had good luck with the AC-Delco in my '89)
    2. Bigger Radiator
    3. Fuel filter and fuel return line
    4. Addititional battery.
    5 You've got hydraboost brakes
    6. Your SM465 is up to the task.
    what else?
  3. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    7. Flywheel.
  4. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Converter, exhaust, starter,
    I would make this change for such only if I had a truck to cannibalize.
  5. MUDNUTT
    Aug 1, 2001
    339
    Mn
    if my smallblock flywheel wont work will one from a 6.2 work? can i use my stock tank if i have it flushed and add a return line? i already have a diesel radiator in the truck so thats not a problem. where can i get the glow plug controler? will the block bolt up to my stock motor mounts?
    deck
  6. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    Glow plug controller (later style '89+/-) is an all in one unit. Steer clear of the aftermarket copies (mine wigged-out after a year) AC Delco ONLY.
    I can't see a problem with modifying your stock tank, people have swapped in EFI units (and a return line) for years now.
  7. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    If the stock tank is galvanized then Id change it out. Galvanized metal and diesel dont mix well.
  8. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    You have never, since I've know you, had enough gas in that tank to worry about flushing it out. A pint of gas is not going to dilute 32 gallons of diesel too bad. LMAO!!!
    John
  9. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I would check the fuel tank pickup / sender part numbers (on gas rigs vs diesel) with the Chevy dealership to make sure they are the same. Diesel has a tendency to wax up at low temps and the fuel pickup may be different. I know it is different on Fords between gas and diesel. Diesel has a dual intake in case one clogs or ices over. A gas pickup would probably be fine in normal temperatures. JT
