Little tranny tech...
Discussion in 'The Garage' started by AkMudr, Jan 30, 2005.
  1. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    I see posts now n then about tranny's..what is this? whats this pan? How long is mine? Well..I compiled everything I have and figured I would stick it HERE!!!!! Make it a sticky if you want. I'll add more to it later
    [font=verdana, arial, helvetica] Just in case you're curious, power loss for various auto transmissions:
    these are approximate values
    [/font][font=verdana, arial, helvetica] Powerglide_____18 hp[/font]
    [font=verdana, arial, helvetica]TH-350________36 hp
    TH-400________44 hp
    Ford_C-6______55-60 hp
    Ford_C-4______28 hp
    Ford_FMX______25 hp
    Chrysler_A904__25 hp
    Chrysler_727___45 hp
    1 Aluminum Powerglide 14 bolts
    2 TH200 Metric 11 bolts
    3 TH350 13 bolts
    4 TH400 13 bolts
    5 TH200-4R 16 bolts
    6 TH700-R4, 4L60, 4L60E 16 bolts
    7 4L80E 17 bolts
    GM Transmission Gear Ratio's
    Transmission
    _Model----------First Second Third Fourth Reverse
    Rear Wheel Drive:
    TH-180C (3L30)...2.400 1.479 1.000 --- 2.000
    TH-200 (& "C")....2.741 1.568 1.000 --- 2.067
    TH-200-4R..........2.741 1.568 1.000 0.674 2.067
    TH-300 (Jetaway)
    TH-350...............2.52 1.52 1.00 ---
    TH-400 (3L80)......2.482 1.482 1.000 --- 2.077
    TH-700-R4 (4L60)..3.059 1.625 1.000 0.696 2.294
    4L30-E................2.400 1.479 1.000 0.723 2.000
    4L30-E Optional....2.860 1.620 1.000 0.723 2.000
    4L60-E................3.059 1.625 1.000 0.696 2.294
    4L80-E................2.482 1.482 1.000 0.750 2.077
    [/font]
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    wow.. good info :waytogo:
    all saved, thanks...
