Loaded 10 bolt front axle, 14 bolt gears & top
Discussion in 'General Parts for Sale' started by WhiteWhomper, Dec 19, 2003.
  1. WhiteWhomper
    WhiteWhomper 1/2 ton status
    Sep 23, 2000
    227
    Highlands Ranch, CO.
    8 lug 10 bolt front axle with warn premium hubs, 3:73 gears, EZ Locker, high steer/crossover arms, 2 sets spare axles, u-bolts and spring plates. $350.00
    Set of used 3:73 gears and carrier for a 14 bolt FF, Open. $ 35.00
    Fiberglass half top from an '87 Jimmy, white with tinted windows....free to the first person to get it away from my house.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Is the hysteer crossover arm different then a normal crossover arm? If it can used for standard lowsteer crossover then I would be interested if you are willing to seperate. If you can use a stock length tie rod (I already ahve a rockrod) with the hysteer arms I would also be interested, along with any other crossover parts you may have to sell. This is if you will seperate the crossover parts from the axle. (I already have the knuckles)
    Are you selling the draglink (bent or straight), etc? Thanks
    Harley
  3. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Is the EZ locker a limited slip or a ful time locker or a powertracks type unit?
    thanks
  4. WhiteWhomper
    Sep 23, 2000
    227
    Sorry, but I don't want to separate/part out the axle. For information though, the hi-steer/cross over arms can still use a stock length tie rod and you can still keep the tie rod in the stock location...the one on this axle still is, as I never got around to the hi-steer before swaping out for a 60.
  5. WhiteWhomper
    Sep 23, 2000
    227
    The EZ-Locker is a full locker that replaces the spider gears, same as the Lockright.
  6. WhiteWhomper
    Sep 23, 2000
    227
