loaded or unloaded calipers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Seventy4Blazer, Feb 20, 2002.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    whats the difference and what is better?
    i can get unloaded for 21.99ea new. and i can get loaded set for like 60 or so.
    Grant
    take me drunk, i am home
    www.geocities.com/seventy4blazer/parts4sale.html
  2. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Loaded calipers come with the brake pads, and unloaded come without them. The laoded ones may come pre-bled with fluid, but I'm not sure on that.
    That's the only real difference I know of ........
    Thomas.
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
  3. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    you might know this one too.
    whats semi-loaded? only fluid or only pads?
    thanks bro
    Grant
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    ttt I am interested in knowing this as well
    Definately a pavement pounder...with the caveman clutch
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  5. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    I've never heard of semi-loaded calipers. Loaded calipers come with pads, no fluid. Even if they had fluid, you would have to re-bleed them once you connected your hoses. I have no idea what semi-loaded are, unless they mean that they come loaded with semi-metallic brake pads, or they come with pads, but they're not stuck in the caliper? I dunno.
    Diesel
    Shouldn't it be called uncommon sense?
  6. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Ditto ..... I've never heard of Semi-Loaded Calipers?
    Maybe they're for tractor trailors? [​IMG] LOL
    Thomas.
  7. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Never heard of semi loaded calipers (now I've been semi-loaded on may occassion!) Unloaded = Just caliper; loaded were caliper/pads & mounting pins/bolts when I asked about them last week @ parts house.
  8. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    Unloaded means it is just the caliper. Loaded means it is the caliper, pads, and the hardware kit (anti-rattle clips, bushings, rubber seals,bolts). No such thing as semi-loaded.
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  9. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Loaded calipers come with pads and mounting bolts, unloaded calipers are calipers only. The loaded calipers come with cheap grade of pads so you may not want to use them. It is usually cheaper to just buy the loaded calipers and keep the pads for back ups and buy some good pads to install. I don't know where you are buying unloaded calipers new for 21.99 ea. but i can buy loaded rebuilts for that price each.
  10. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    they are 11.99 but a ten dollar core charge. i am not turning in calipers so i figure the cost is then 21.99
    it would cost about the same to buy loaded calipers or buy them all seperate. i got the bolts already. but i dont know. i will find out what kind of pads are on them. and a spare set of bolts would be kind of nice.
    Grant
