LOC Question
Discussion in 'Audio' started by Resurrection_Joe, Dec 10, 2004.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    When using a line output converter do you splice into the speaker or change the connection from the speaker to the LOC
    What I mean to ask is, are the speakers you used for the LOC still hooked up or no, meaning do you need a tiny lil amp to power the speakers that you circumvented
  2. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    Holy piss, I was just about to post a question that somewhat has to do with LOC's....
  3. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Hmmm hopefully someone will shine on down
  4. Capman2k
    Jun 22, 2001
    5,070
    dg
    I'm about to go hook up an LOC I bought today while at work... I'm assuming all I need to do is hook up the speaker wires the way the instructions say and all will be well... I'll let you know if the speakers I use still work after I hook up my amp :D
  5. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
  6. Capman2k
    Jun 22, 2001
    5,070
    dg
    Okay, here's what I got...
    Take the speaker wire, and cut it... connect both pieces that you just cut to the wire for the LOC, and tape them up... Do that for the positive and negative wires for both speakers you're going to use...
    Then do the same 3-way style connection for the constant power, ground, and power when the stereo is on...
    Easy enough... Now if I could just figure out why in the name of God my amp isn't getting power, when there's power going to it :( :(
  7. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I ended up buying a $80 wiring harness to dump a pioneer deck in my Malibu
    I am such a consumer whore
  8. Capman2k
    Jun 22, 2001
    5,070
    dg
    Yes... You are quite the whore...
