Location of neutral safety switch and
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 80Jimmy, Jun 22, 2003.
  1. 80Jimmy
    80Jimmy Registered Member
    64
    Idaho
    I bought i floor mount shifter and needed to know were the neutral safety switch and the reverse switch are at. Its an 83 6.2 L diesel
  2. tRustyK5
    Jul 23, 2000
    36,164
    1,360
    E-town baby!
    All that crap is down by the ignition switch at the base of the steering column. It helps a lot to drop the column down for access to a lot of it.
    Rene
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Does the new shifter have the cut out on it? The Camaro (floor shift model) still uses that stuff on the column. All you would need is the different shift linkage that allows for the shift cable and the column shift rod. The only difference would be the column has no provision for the shift lever.
    You might want to look into a factory style setup so you don't lose features like the shift indicator. Just a heads up...
  4. 80Jimmy
    64
    Idaho
    It is the b&m Z-gate shifter
