Location of power door lock relay
Discussion in 'The Garage' started by engrgrad, Aug 1, 2004.
  1. engrgrad
    engrgrad Registered Member
    Jul 18, 2004
    32
    Michigan
    Trying to track down the reason why one of my power door locks on my 88 suburban isn't working. Motor is ok when connected to a power source but the one plug isn't getting any power. Now I have to trace the wiring back from the bad door to the relay. Does anyone know where the relay for the power door lock system is located?
  2. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I have the same exact problem and haven't had much luck figuring it out. I know its somewhere above the steering column. I think more to the passenger side. Let me know if you figure it out. Take a picture of the relay so I can see it too.
  3. Bruiser
    Bruiser 1/2 ton status
    May 21, 2000
    320
    Caldwell,Idaho
    Don't know how much they moved them around but mine on my 78 were attached to the pedal assembly, right above the gas pedal.
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    What he said, I had no idea until I did a tranny conversion. It's tucked way up there on the right side of the pedal mounting bracket. Not too far from the brake light switch.
  5. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    My doorlock problem was the wire was broken where the door hinges.
