lock cylinder removal
Discussion in 'The Garage' started by nocoasthardcore, Nov 22, 2004.
  1. nocoasthardcore
    nocoasthardcore Registered Member Premium Member
    Nov 22, 2004
    35
    i am trying to change the lock cylinder in my 1989 k5. i have pulled the steering wheel and the lock plate and the turn signal switch. now what? thank you
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there is a small screw near the upper edge of the cylinder, remove that and the cylinder comes out. /forums/images/graemlins/waytogo.gif
  3. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Put the ignition in the run position,use something thin to slip behind the lock cylinder work it back and forth and down at the same time.Should pop loose,at least it worked on my '73.Hope that helps. /forums/images/graemlins/usaflag.gif
  4. mr_beer
    mr_beer 1/2 ton status
    Sep 10, 2004
    325
    Mt. hermon LA
    Yea I changed doors and had to swap the old ones out, but I think the newer ones are different as big83 said /forums/images/graemlins/dunno.gif
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the 78 and older had a different way of holding it in, used a narrow spring loaded bar, the 79 and newer used a small screw.
  6. nocoasthardcore
    Nov 22, 2004
    35
    Thank you all for the help. i do not have my key*thus the replacement*, so no putting it into 'run'
    i posted twice, i did not realize the forum went so quickly and thought there had been an error.
    also. i was surprised at the difference between the autozone part and the delco. the delco part is much heavy. even the keys themselves have a more comforting heft.
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    How many GM keys do ya have?
    Start doing the jiggle and ya might get lucky.
    Or call in a locksmith.
