Lock It?
Discussion in 'The Garage' started by ssped, Feb 6, 2007.
  1. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I need Help with a decision. To lock it or Not to lock it, That is the question. (never thought we could Shakespere in a Ck5 forum) Here is the build and I would be using a Mini spool more than likely.
    82 Blazer, 6.2 diesel, 14bff rear with a detroit and disc brakes, 6" front springs and 1.5 shackles, rear is a ORD 4" shackle flip, Xover steering on a 10b(open at this time) all running on 33's.
    Should I lock the front or not? I am worried about strength. will the axles hold up at all or will I just tear it apart. remember I am light footed with a diesel. I would like to run the 10b for another year before swapping to a 60.
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if ur going to eventually swap in a 60, dont waste the money on a locker for the 10b. 10b + locker = axle shafts go bye bye
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,993
    130
    I agree
  4. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    I am sooooo back and forth on this. Today I am in a leave it open mood but yesterday It was a lock it mood. I am going to sit on this for a week or 2 to decide.
  5. goldwing2000
    goldwing2000 Guest
    If you're going to waste... err... spend money on a spool, might as well just weld it. Especially if you're already planning to replace it.
  6. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,021
    849
    Pinckney, MI
    Weld it. Really easy to do on a 10blt /d44
  7. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
    Are you certain you'll have a 60 within a year. If it's going to be 2yrs more, I would lock it up with a Lock-rite. When you do get a 60 you have a better chance getting some money for the axle or even part out the locker and sell it individually.
    Personally I wouldn't be so worried about axle breakage. You describe yourself as light on the throttle and you're only running 33s. I feel the front locker makes it easier to "crawl" obstacles without getting heavy in the throttle anyways. Heck I ran a locked 44 on 37s. :dunno:
    I would recommend swapping in new axle shaft ujoints since you gotta pull them anyways. Also do a full circle clip conversion while you're at it.
    Just my .02
  8. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    the front does not have C clips and I was thinkin 100$ Mini spool. Maybe I will weld it though.
  9. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I say weld it or leave it open. theres no use in wasting money if you're going to get rid of it. If you want it locked then weld it. I ran a welded d44 (which is pretty much the same thing) for 6 months and had no problems with 35s.
    If you plan on getting a d60 then there is no point in spending money on the 10b. so like I said, weld it or leave it open.
  10. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    HIJACK ON
    i have a 3/4 TON 10B up front and a 14BFF in the rear both with 4.10s open and plan on going 38x14.50R16.5 I am gonna lock the rear but should i lock the front? I do mud and trails LOTS A MUD MUD.
    HIJACK OFF
  11. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    I say lock it. I wheeled open for 3 years and locked for 1 and will never wheel with an open diff again. those tires will be hard on a 10b but with it locked it will crawl a little easier and you wont have to use the throttle as much so it might be ok, plus if you have a 14bff rear you'll at least be able to make it home.
  12. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I was also thinking 33s or 35s.
