lock nut Torque?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by windrider, Mar 9, 2001.
  1. windrider
    windrider Registered Member
    Mar 3, 2000
    52
    Wisconsin
    My lock nut for my front wheel bearing is loose. What should be the torque on that? I thought my auto hubs were giving me grief so I bought some warn premiums. Guess I didn't need them but they are going in anyhow!
  2. jerseyk5
    jerseyk5 Registered Member
    Jan 26, 2001
    42
    NJ
    Just looked it up, its 12 ft lbs!!
  3. windrider
    Mar 3, 2000
    52
    Wisconsin
    Thanks alot...now I can continue on!
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Uh, is there a zero missing somewhere? 120 sounds a lot closer to the real deal than 12.! [​IMG]
  5. windrider
    Mar 3, 2000
    52
    Wisconsin
    Which one? Is it 120 ft lbs? or 120 inch lbs. They were both loose. Do I need to retighten them tighter?
  6. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    First, tighten the first nut against the bearing at 50 ft lbs while turning the wheel. Back off a 1/4 turn and tighten to 35 ft lbs. Then back off 3/8 of a turn. Then put the locknut on at 160 - 205 ft. lbs. Of course you need the special 4 pronged socket to do this. I hope this helps.
  7. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    My 78 shop manual says at least 50ft lbs.
  8. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Yes, do like the BlueBlazer guy said. I can never for some reason, get it to 160 to 185lb torque for the life of me, but I just get it as tight as possible. (this is the outer lock nut). For the inner one, do the steps like BlueBlazer said.
    Boss
    <A target="_blank" HREF=http://www.boss.coloradok5.com>http://www.boss.coloradok5.com</A>
  9. windrider
    Mar 3, 2000
    52
    Wisconsin
    Thanks, Well, better get to tighten those up a bit!
  10. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    yep, 35 for the inner and 80+ for the outer. The haynes manual is a bit tricky when it envolves multiple models. I've had mine at the above setting for a few months now and no problems.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
