lock nuts on valve covers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by personaltrainer, Nov 15, 2004.
  1. personaltrainer
    personaltrainer 1/2 ton status
    Nov 4, 2004
    178
    Atlanta GA
    quick question. If I'm using the crappy parts store ($40) edlebrock valve covers (with felpro rubber gaskets) would it be wise to use lock nuts to tighten them? or is that just asking for trouble? It seems that everytime I check them they have loosened (i guess due to the expansion and shrinkage b/c of opperating temps). Will the lock ones just warp the hell out of valve covers when it heats up? Thanks
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    you should lock tite the studs in, use load spreaders and the lock nut will be fine
  3. personaltrainer
    Nov 4, 2004
    178
    Atlanta GA
    Yeah I went for it. No more leaking! Finally. thanks.
