Lock-out hubs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fulltopblazer, Apr 10, 2002.
  1. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    I'm converting a 74 d44 to 8 lug with parts off of a 78 d44 8 lug that is full time. Will my lock-outs off my 6 lug be the same? I noticed on 4wpw's website that they list different lock-outs for 3/4 ton.
  2. fulltopblazer
    Aug 1, 2001
    484
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If your locking hubs off a six lug are internal style hubs, then they should. If they are the earlier external style then no. 1/2 ton and 3/4 ton hubs will swap from what I understand as long as they are the same style (internal, external).
  4. fulltopblazer
    Aug 1, 2001
    484
    How can you tell the difference? Is it something that is very noticable or will I not know until I get it torn down? I'm just trying to make sure I have all my bases covered before I tear it down my shop space is very limited. Thanks
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    My truck has internal hubs. There are pictures of it in my signature. Exteranl hubs are huge. I will see if I can find a pic.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ok, I reread your post. If you are using 78 parts to convert then you should be ok. 78 should have the internal style hubs, and if it is fulltime then you should be ok. As long as the hubs off your 1/2 ton are the same size as the hubs on the 78. I am thinking that external hubs were on only 3/4 ton models prior to 76. (not positive) Your hubs should be fine, but someone else here will be able to tell you for sure.
