Lock-Right and Hub Fuses
Discussion in 'The Garage' started by Rob 85K5, May 31, 2005.
  1. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    I know you're not suppose to use hub fuses with a detroit locker because if the fuse lets go it trashes the locker.
    Does anyone know if this is the same for the lock-right?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I would ASSUME the reccomendation is the same . I got some , then got skeered and traded them for some rims .
    What I don't understand is how it ruins a locker . I thought if a hub fuse blows , that axle is still moving , just nothing making it to the locking hub , like a tire in tha air . Just don't make sense , both axles turn the same speed , under load or not :dunno:
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Don't do it Rob !!!
    The L/R can't handle the sudden shock of that axle being free'd up and bad things will happen to your new parts.
    Tom
  4. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    I don't know about the lock-right, but the No-slip can handle a broken shaft. I have one in my 10-bolt and it survived a broken shaft just fine. I also called Powertrax and spoke with one of the tech. support guys about this, he claimed that in most cases the locker will survive a shaft failure.
  5. Rob 85K5
    1,487
    Pensacola, Florida
    I'll have to put the old gears back in.
    BTW, it appears I have a Detroit EZ Locker, and not a lock-right, not that there is any difference. I was just calling it what the previous owner called it.
    Found out ordering the service kit for new pins and springs.
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    There is a difference, EZ-lockers suck, I have heard of almost everyone who had one have some type of problem with them. Get a lockright and dont look back.
  7. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    :confused: :confused:
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Jay :
    That and I couldn't afford a front locker to try them , 20 bucks says you will be fine considering how often my old Ez Crocker rear popped hard in 9 months at speed on the street with over 5000 pounds ;)
  9. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    It still shock loads the locker. It goes from having a bunch of torque on it, to all of a sudden nothing. Its just like breaking a shaft, only it takes a little less torque to do it.. You really shouldnt run them with any true automatic locker.
    I personally hate hub fuses, but thats just me and my opinion.
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    hub fuses are retarded. Why build beef then install a purposefuly weak link?
  11. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you are running hub fuses it means you have a 1/2 ton front axle. This means that no matter how much you "beef" it up it is still not bulletproof. You use hub fuses for 2 reasons.
    #1: They are alot cheaper then the other axle components like lockers, shafts, ujoints, etc.
    #2: Replacing a hub fuse is alot quicker and easier then trying to replace an axleshaft. Or if you break a locker or ring and pinion you are toast. No 4WD. Have fun getting of the trail with no 4WD.
    Harley
