Lock right in D60 Help
Discussion in 'The Garage' started by 1987Blazer, Jan 14, 2007.
  1. 1987Blazer
    1987Blazer 1/2 ton status
    Apr 9, 2005
    168
    Murrieta CA
    I'm trying to install a lock right locker in my open D60. Are there two diffrent size roll pins that hold the center pin into the carrier. I got the pin out but the holes look like diffrent sizes 1/4 and 5/16 back of ring gear. Having a hell of a time getting all the roll pin material out of the hole on the back of the ring gear thinking of drilling it out?:confused:
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The roll pin goes in & comes out the same side (with the larger hole). The smaller hole is just for your punch.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Don't drill it. The roll pin only goes in one way.
    I though I remembered to tell you that when I dropped of the steering crap??? I might have forgotten to though.
  4. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    You are talking about the small pin that holds the cross shft in place, correct? If so, I am with you. I had a heck of a time and finally found a long piece of thin metal and was able to get it int he hole and drive it towards the drivers side.
  5. 1987Blazer
    Apr 9, 2005
    168
    Murrieta CA
    Hey Readymix you told me but then I forgot.:o Anyway I drilled it from the side with the large hole with a bit the size of the smaller hole. That pin would not move. Is the large hole the same size all the way to the pin in the carrier? or does it taper? Part of the roll pin that came out In one piece was small in diameter.
