Lock Right install......
Discussion in 'The Garage' started by jimmyjack, Oct 30, 2003.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Is installing a LockRight in a front 10 bolt as easy as openeing the diff cover, dropping the cross pin, removing the spiders and installing the locker? Or do you need to remove the axleshafts from the end? Seems to me that you only need to remove the diff cover.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You will need to pull at least one axleshaft back so you can get the whole mess into your carrier. I'd think you'll have to pull both of them. I've never installed a lockright in a front axle though so never attempted it with only one side apart. When ya do a rear it's just too easy to push the shafts out and be done with it.
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Thats where I'm getting all cornfused. There are no c clips so I don't think you need a lot of room. I'm not doing it but I was having a discussion with a friend who had talked about doing it. ( I'm DONE with lockrights)
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
  5. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Cool, thanks cousin. Just what I needed. Pulling 1 is better than both I guess.
