Lock Right or EZ-Locker
Discussion in 'The Garage' started by K5on38s, Sep 8, 2003.
  1. K5on38s
    K5on38s Registered Member
    Dec 11, 2002
    90
    Buffalo, NY
    Ok this isnt for anything huge, its more of a plow truck (86 K5 blazer 305 4" lift 34's), He usually only takes it on the road if it really bad out. But he wants to replace the 10bolt gov-exploder which should he get... and are they good? /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have heard people like the ez-locker better
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    As a reminder, if the truck already has a Gov-lock then you cannot install a Lock-right or EZ locker unless you also install an open carrier. In my opinion he would be better off just installing a good aftermarket limited slip like an Eaton Posi or Detroit Tru-trac.
  4. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    A nice tight limited slip would be good for a plow truck. When my Gov-Pop /forums/images/graemlins/rotfl.gif exploded in '96, I put in a Auburn limited slip and it's been OK ever since. I have beat the absolute piss /forums/images/graemlins/blush.gif out of my 10 bolt rear with 35"s and it has held up well. Not perfect for off-roading, but for a vehicle that's mostly street/snow with a little mud thrown in the mix, it'd be fine.
  5. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Where did you hear that? The only ppl I know of that were satified w/ the EZ were those who got the 1st run. After that they were "improved" to be less like the L-R and became a POS. I do not know ANYONE who has an EZ that lasted more that a yrs worth of wheeling. I have heard one or two ppl on the net say that they worked, but they all bought them in the mid/late 90s. The EZ is a POS, stick w/ the L-R. A L-R will last in a K5 w/ 10Bs and 38s untill a shaft lets go. An EZ will NOT last in a K5 w/ a 12B & 35s. Nor will it last in D30 under a CJ5 w/ 33s.
    K5on38s; Do a search, this has been covered on here A LOT, but its been quite some time (maybe close to a yr). Either way if he has a Gov'Lock now he will need a new case. While 10B cases are easy to find in a JY, its not realy worth it. Buy a full case diff, either an Auburn LS or a real Detroit would be good choices for what you described.
