lock-right slipping
Discussion in 'The Garage' started by Jishory, May 4, 2006.
  1. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i installed my lockright up front, installed everything as the instructions say, kept the thrust washers the same as the spider gears. when i give it more then 1/3 throttle the driverside pops in and out of lock. do you guys think heavier springs or thicker thrust washers would help keep the teeth in contact better?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Been there , and done that with the other guys ( GG Quic Loc , aka Detroit EZ ) . After about 6 months of use .
    I tried all different combinations , and it would work for a while , and come back . Kept having them tell me eithr the teeth are stripped , or the carrier is out of spec .
    Bought an honest to goodness Powertrax Lockright , and had no problems for over a year and a half .
    If your IS an honest to goodness Lockright , I would measure all the clearances and post back up and maybe Springer can see it . I know he would say use a new crosshaft/pinion pin as well , as they wear as the locker rubs it .
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Get the thickest thrust washer GM has for it and a new cross pin.
  4. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    is is a lock right, the teeth look fine. ill go to gm tomorrow and get some thick ass thrust washers, possibly get some pics/video of the slipping if its still going on
  5. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    josh, I have some extras, Ill grab them tommarow :thumb: :burb:
  6. sebban
    sebban Registered Member
    Jan 18, 2005
    63
    sweden
    I say get the cross pin!! That´s what cured my setup.
  7. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    im getting one through a bud, the dealership up here wants me to buy an entire kit for 400$ to get that...
    ill take you up on those thrust washers dom:D ill be in my garage when your free
  8. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
