Lock Right
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LaxRox5, Dec 15, 2002.
  1. LaxRox5
    LaxRox5 Registered Member
    Nov 5, 2002
    27
    Maryland
    Well I have finally narrowed down the clunk in my rearend to the lock right installed by the PO, but im not sure what could be causing it. I was hoping i could get some pointers on here that might lead me to being able to find out what would need to be done to stop the clunk. It occurs during hard acceleration, but recently it occurs whenever it wants to. I had to park the burb it was so bad. /forums/images/graemlins/burb.gif
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Speaking from experience /forums/images/graemlins/angryfire.gif Check the pins to see if they are in one piece. They break in half when under a lot of stress. Also remove the lockright and inspect the surfaces and look for burrs, chunked out areas on the grooves. Stuff like that.
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Some lockrights need a hardened cross pin. If you don't have one, it could be worn to the point of having LOTS of slop. Pull the diff cover and clean it up good. Give it a visual inspection. You should be able to see/feel where the play is.
