lock up conveter??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by efilnikufecin, Jul 24, 2002.
  1. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    how do you rewire a 4L60 so i can manually lock up the converter.anyone got some prints?
  2. dyeager535
    26,975
    For one, I believe shorting ALDL pins A and F should do it. (if this is your '91 you speak of) (top pin in the upper left and right corner of the connector I believe)
    You could always put in a toggle switch that wasn't hard wired in that way too....there is a website out there (try searching for ray buck chevy asylum) on yahoo, and check it out. Theres a write up or diagram of how to wire it there I believe.
    Why would you want to manually lock it in your '91?
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  4. efilnikufecin
    Feb 27, 2002
    168
    flint,mi
    trying to see if i can get any compression braking out of it for decents.i also would like to lock it in on the express way so it don't keep locking and unlocking.
  5. dyeager535
    26,975
    Easy enough to test the compression braking idea with the shorting of the two ALDL pins. That method works (as long as the trucks use the same ALDL wiring as every other GM vehicle that used that connector until '91 or later) as I've done it myself.
    I guess it would be kind of hard to do while your driving though on the trucks. That ALDL connector is in an odd spot if you ask me...great for using a scantool on, bad for trying to watch voltage or short pins to test.
  6. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Maybe if he has any small children, they could sit on the floor and run the ALDL, haha.
