lock up or not?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, Mar 30, 2002.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    i don't know how to tell if my 700R4 is a lock up or not. how can i tell?
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    There should be the vac. control for the lockup on the pass side of the firewall. Its a little piece of plastic with a vacuum line going to it.
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    All 700R-4 trannies are lockup.
    If the lockup fails and you continue to load the trans in OD, the OD will roast becuase the pump is not supplying enough pressure.
