Lock washers on adapter plate
Discussion in 'The Garage' started by 4whler, Jan 10, 2004.
  1. 4whler
    4whler Registered Member
    Nov 6, 2003
    12
    Middle of TX.
    Started to bolt 203 to 400 adapter plate on and noticed that only two of the old bolts had lock washers on them. Do you put them on, does it matter.Also the plate only had one of the little rubber washers left in it pretty sure I need these.Tried searching thanks in advance.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If those bolts come loose it can wreak havoc on your transmission case. In addition to lock washers on all 4 bolts, I would also clean the bolts and bolt holes with brake cleaner and then apply a liberal amount of Loctite to each bolt, the 4-wheeler's friend. /forums/images/graemlins/wink.gif
