Lockbox / Console for Blazer(73)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bobsurf, Jun 26, 2001.
  1. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    I'm looking for some type of Lockbox or center console to keep valuables in while the top is off. I've got a 73 Blazer, it's 80 degrees outside, and I've gotta have somewhere to put the important stuff while surfing. A keyless model would be ideal (combiniation lock, converted safe, etc.) Ideas?
    Newbie, 73 Blazer project
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I don't know of any combination ones, but check out Tuffy Consoles, forget their website, but Steve has an article on it in the products page here on this site. I have the Tuffy, and I lock all my stuff in it. No vandals since, and before I had it, my truck been robbed twice!!
    Boss
    89' 1 TON of FUN K5
  3. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Check out Tuffy Consoles, they make a couple that should take care of your needs. I use the Security Stereo Console in my K5 (12" wide version) & also one in my 68 Bronco (8" version). Very tough to break into and perfect place for CD changers, stereos & CB's.
    87 K5, D60 & 14FF, 5 sp & NP208 & 383 stroker. Build it Bulletproof and take it fishing!
  4. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Heck i went down to the steel yard and bought some 14 gauge diamond plate. Made a console that holds my reciever, eq, and inside holds my 10 disc changer. Has a flip top lid, and it's stout as hell. You can stand, sit, and jump on it if you wanted too. Also water proof, and made a cover to go over the top of it so it is pretty much theft proof and you can't even see the stereo or eq with it on. Oh yeah getting it rhinolined too. I should get some picks someday. Later - Doug
    Doug Krebs
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I thought about this, but then I got to thinking. If someone really wants what's in there, they will probably going to get it. All they have to do is unbolt the box and steal it. Make sure you botl it down real well...maybe even use some security torx head bolts like the ones that come on the tops of our K5's if you can find some. I don't know how likely it is that someone will unbolt the thing, but just something to think about.
    90K5
  6. Sparky87k5
    May 6, 2001
    726
    I bolted mine down with the bolts going up into the console and then used castle nuts with cotter keys thru the bolts. Impossible to remove without access to console. I used 4 3/8" bolts thru custom framework for mounting seats & console.
  7. Steelhead
    Steelhead Newbie
    Jun 22, 2001
    If you want some thing that will be cheap to buy use an old ammo can they come in all kind of sizes just add a clasp lock paint it or Rhino line it or even carpet it and bolt it in.
