Locked front 10bolt?
Discussion in 'The Garage' started by BowtieRed, May 12, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    I need more traction! I have an open 10b front and was wondering if i could just weld the spider gears together with it still in the housing? I don't need to ever be able to unlock it- as i'm getting a D60 sometime in the future- i also have locking hubs, so i can still use it on the road.
    is this feasible? is it smart? i need the extra traction in the mud, especially until i get my 44 TSL /forums/images/graemlins/grin.gif
  2. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    It's ok as long as you only want to go straight. Turning will suck. Isn't there another post in this forum about this same topic.. try doing a SEARCH for better answers. /forums/images/graemlins/ignore.gif
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Three wheels spinning is better than breaking a shaft or joint cause you welded it. You're already way past its limit with a 40" tire.
  4. K5Kell
    K5Kell Guest
    I would only do it if you allready have a D60 you are about to buy, then who cares if you blow the 10blt /forums/images/graemlins/laugh.gif. also if you dont need to get to work in it.
    -Kell-
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    get to work! that what the rear wheels are for /forums/images/graemlins/laugh.gif lol, i guess i'll just wait on the 60 and lock it.
  6. thechevyman
    thechevyman Newbie
    May 14, 2003
    Reynolds, ND
    I welded the corporate 10 in my short box and about every month depending how many full throtle dounts in 4 hi and hills climbed while sawing the steering back, it would eat both u-joints and usually an inner and outer axle shaft. That was just with 31's, with the 36's i could turn the wheels at full lock and flour it, it would usually spit a cap off and eat the passanger side inner and outer.
