Locked Rear?
Discussion in 'The Garage' started by longbedder, Apr 17, 2007.
  1. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,203
    366
    Ridgecrest, CA
    I just picked up a '94 Burb K2500 - sweet deal BTW. It's got a TBI 454 with a Whipple supercharger and 4L80E.
    Anyway, it has a 14BFF and I was wondering if those axles came from the factory that year with any sort of traction devices. Part of my RPO list is obscured, but if you are aware of any to look for, post 'em up.
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    if it says G80 then its got a gov-loc.
  3. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    I didn't think you could get a ff in a 'burb after about '88-'89. Otherwise, yeah, G-80 is the only code I know.
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yep, the 1992-99 K2500 Burbs with the 454 got the 14BFF.:D
  5. longbedder
    Oct 26, 2005
    4,203
    366
    Ridgecrest, CA
    So the Gov-Loc was the only factory traction device they put in 'em in 1994?
  6. goldwing2000
    goldwing2000 Guest
    If your RPO codes are fubar, best bet is to pull the cover and have a look. Once you get it off, it'll be obvious what's in there and then you can inspect the gears and change fluid while you're poking around.
    Alternately, you can run the numbers stamped into the top of the right side tube.
  7. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The Gov-Loc was the ONLY factory traction device available for the 14BFF ever......(excluding military vehicles):wink1:
  8. goldwing2000
    goldwing2000 Guest
    I could have sworn some of them came with posi. :thinking:
  9. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    I have service manuals from 74 and 85, neither mention a posi, only the Gov-lock, in the GM full float axles. The Dana axle has the PowerLok unit.
  10. goldwing2000
    goldwing2000 Guest
    Hmm... interesting. *shrug*
