Locker advice
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SVBlazer, Mar 31, 2002.
  1. SVBlazer
    SVBlazer 1/2 ton status
    126
    Boxford, MA
    I've been advised to update (thanks marv springer), my rear diff in preparation for blazer bash 02. So the question is which "box locker" to buy?
    Please let me know your experiences with LockRite, Powertrax, Detroit E-Z locker etc.
    Before you all start..I know, a new carrier and true locker is a better fix. I just have the time a money for the quick fix...
    Blazer details: 85, 2.5 inch lift, open 10 bolts, 3.73s, 33s, 383 and 700R4.
    Thanks in advance!
  2. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I don't have any experience, but I have never heard anything good about the E-Z locker. The LockRite is supposed to be pretty durable, but a litte loud. I believe the Powertrax is basically just an upgraded LockRite for smoother and quieter operation.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    There is no such thing as a quick fix, just as there is no such thing as a cheap fix. Do it right the first time and never do it again. Extra money spent now is money well saved later.
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    The powertrax hold up better to bigger tires, and last longer than the lock right. The detroit ez lockers suck stay away from them.
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I have 33's, 3.73's and I love my Lock Right. I had an Auburn that was "all burned" out. The Lock Right clicks a little bit but it's not loud. And I crawl up stuff I used to work hard at. It cost me $250 and once I got my open carrier installed it took less than an hour to install it and fill up the diff and test drive it. It's really simple.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you plan on getting a 14bff down the line, or plan on ditching your current axle for something else then just get one of the lockers you mentioned. If you don't plan on upgradeing then do it right the first time. Get a Detroit, or an ARB.
  7. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I too have been looking for an insertable locker, I was looking at the genuine gear "quick lok." They are made by tractech and cost only $280 for a 12 bolt. Anyone have any experience with these?
  8. mudober
    mudober Registered Member
    Feb 19, 2002
    23
    I have 78 Jimmy with a lock rite 35 inch Gumbos,3.73 gears,208/700R4 406small Chevy EDL. Package.
    It makes a clicking noise when turning if your off the power.
    When i"m on pavement I try to coast around corners.I love the attention I get in parking lots.I've had it on one front & one rear
    & done some posi burn outs hasn"t broke in the three years its been in.
  9. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I have three Lock Right lockers. They are good stuff. Just another way to "do it right" and they are cheap.
    Makes me laugh, lotta times the same people who are against drop in lockers are against lockers in general and are still running open diffs. They don't follow their own advicce AND they get stuck a lot LOL!!! /forums/images/icons/smile.gif
  10. SVBlazer
    126
    Boxford, MA
    Thanks for all the feedback. Yes I plan on a 14ff down the road, ARBs with 4.10/4.56, but that's another issue. Just got to get right for Blazer Bash!
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Unfortunately they don't make an ARB for the 14 FF.
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    weld the rear
    lockrite the front
  13. lsak5
    lsak5 Registered Member
    Mar 19, 2002
    26
    Marietta, GA
    I've got a Powertrax and I love the little guy. Every once and a while I get some racheting from him, but other than that No Problems at all. MJ brought up a good point of welding the rear, I don't plan to upgrade to 14 bolts, Plenty of 12 bolts out there to throw the chunk w/ gears Powertrax and disc brakes on. And I figure if I haven't broken it yet, I probably won't. Went throw some rough stuff during the rainy season here in GA.
    Good Luck
    Luke
