locker-pop
Discussion in 'The Garage' started by 4trolls, Jun 26, 2005.
  1. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    I have a loc-rite in my 14bff on a 78 sub, when I turn it sounds like someone rearended me , people on the other side of the intersection look to see what I hit. Central 4x4 says that its all good,but I have not heard anybody eleses truck making this sound. all my friends have arb or welded so I have no compairison. my truck is a stick ,so maybe thats why, does any one else have this?
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    did Central install it for ya? if so, get a second opinion. I have found them to be a little shaddy, and definitely over priced on some stuff too. If they installed it, maybe they are just trying to avoid the shop time / replacement costs.
    j
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    How often does it pop ?
    My Quic Loc/EZ Locker did it all the time , made me mad , would try different thrust washers and gear oil , worked awhile , came back to popping .
    Now my Lockright I have now , perfect , popped 5 times in 4 months :D
    You have to be easy giving it back throttle after a corner , you will learn to nudge it just right .
    I would take it back if its a Powertrax brand Locker , and you drive fine . Get it warranted .
  4. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    It pops anywhere from 1 to 8 times on a right turn ,and not usually a pop either ,its a bang. its the same as the day they put it in . I think if this is normal I will be welding it up , my jeep has a welded rear and its fine
  5. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    My lockright has poped maybee 5 times in 6 months, but when it does pop you feel it through the whole truck and it always makes me think i finally broke an axleshaft. Yours poping that much doesnt sound right.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The teeth are worn already , or theres too much play , take it out for warranty . They shouldn't pop that much .
    It should maybe do it ONCE after a turn if you jump right back on it , or after a lane change if you jump in and out of the thottle , but thats it .
  7. rodney chambers
    rodney chambers Registered Member
    Jun 23, 2005
    50
    northeast oklahoma
    locrite pop!
    i have a lockright in front on my 80k5 10 bolt front . when it unloads it sounds like a cannon went off. got a buddy with a zuk that does it too. no problems though.
  8. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Unless you replaced the carier too, it might be a worn carier causing your problem. My EZ-Locker popped occassionally when I installed it. Once it started popping regularly it failed soon after.
  9. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    I just drove around and I noticed that I put the clutch in around turns, so I tried gassing into turns and that seems to make it better,but I am going to get a second opinion
  10. rodney chambers
    Jun 23, 2005
    50
    northeast oklahoma
    right on. check that oil for metal too.
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Ahh , manual tranny , that would make a LOT of difference . Try to put it in the gear you need before the turn and ease into it coming out .
  12. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Loc-rite.
    Mine would "Tick" as I went around a turn , which I've been told is normal. The ticking would get louder and faster as it went faster in a turn, unless I gave it some gas, and then it would lock, but loud banging I don't think is normal, it may need to be re-shimmed inside the carrier. Sounds like it's too tight to me.
  13. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    No , its too loose when they do that all the time , or the teeth are worn , tight is good , it actually tightens as you apply power .
    When you give it gas , the pinion turns ring gear , carrier turns , locker couplers get caught on the crosshaft and push out couplers , couplers lock onto drivers and turn axles . Tight is better :D
  14. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Not to jack, but it might help to know that I've had a similar problem. I've had the Detroit for over a year, and since I've had my new tires a month? I've had the rear end bang twice (coincidence?). And like was mentioned it sounds like I was rear ended. I actually got out the first time to check! The only difference is both times was from a stand still and I was going straight. No ideas yet.
  15. LongIslander26
    Jun 25, 2005
    256
    Lockers
    I've heard those Detroits are pretty harsh, but the loc-rites and those like it aren't supposed to be. "Ticking"-good, "Banging"-bad. :D
  16. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Check tire pressures , they need to be aired up to the same diameter on each side , not necessarily the same pressure .
    Measure all 4 tires diameter at one set pressure , take the two that are closest to each other . mount them out back , and then adjust air pressure for closest diameter to each other .
  17. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They can still still bang , but don't seem to do it very often , and almost seem not there in an auto truck driven normally .
  18. LongIslander26
    Jun 25, 2005
    256
    Lockers
    That's what I had mine in, a 78 GMC half ton 2wd automatic. It would bang every now and then, but not like I had been rear ended, usually just a quiet ticking going around turns. Only when I got silly with the stupid pedal did I get any real noise out of it. :p:
