Locker Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by badfish4tail, Oct 4, 2005.
  1. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    I just bought a 14blt ff, My question is this a Detroit locker in it?
    Thanks..Mario
  2. badfish4tail
    Mar 1, 2005
    1,684
    Long Beach
    one more pic
    and thanks again
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    It looks like it's got a Detroit, to me. :thumb:
  4. badfish4tail
    Mar 1, 2005
    1,684
    Long Beach
    SWEET :saweet: Thanks for the info :D
  5. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    looks like scrap to me. lucky for you i deal in the disposal of scrap. ill PM you my address :haha:
  6. badfish4tail
    Mar 1, 2005
    1,684
    Long Beach
    I also deal in the disposal of scrap, that how i got it :D
  7. Bigg R
    Bigg R Registered Member
    Feb 21, 2005
    34
    Martinsville,Indiana
    Looks like a stock GM locking differential to me!!!!!
  8. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    it's a open carrier but I can't tell if it's just the side gears that I'm seeing or detriot.
  9. Bigg R
    Feb 21, 2005
    34
    Looks just like the rearend in my 95 1 ton w/locking diff. these don't look like your typical gov-lock as in a 1/2 ton 10 bolt!!!
  10. badfish4tail
    Mar 1, 2005
    1,684
    Long Beach
    So how can I tell if it's a Detroit or not? :confused:
    Is thier any kind of markings? :mad:
  11. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    DETROIT FOR SURE :D i just did 2 the last week or so.:p:
  12. badfish4tail
    Mar 1, 2005
    1,684
    Long Beach
    Thanks for putting my mind at ease :wink1:
  13. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah yeah its a detroit.
  14. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I'm not sure what you're saying. Are you saying the "locking diff" that came in your 95's 14 bolt is not like a 10 bolt, because the 10 bolt used a gov-lock?
  15. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    It has 4 cross pin holes, and you can slightly make out the detroit internals inside the carrier. :thumb:
  16. Bigg R
    Feb 21, 2005
    34
    The 10 bolt governor and ratchet pawl are visible as you look at the carrier!
    The 14 bolt FF is a two piece design carrier, the governor mechanism and ratchet are only visible if the two halves are separated. The holes around the outside diameter of the carrier are for the cross pin, there are 3 spider gears that ride on this pin, the open differential has 4. The carrier in my 1 ton has 3 holes around the diameter of the carrier therefore it is essentially a Gov-lock
    14 bolt!!!! Upon looking at the pictures again, this looks to be an open carrier
    because of the 4 pin holes! I have an exploded view of this carrier if you would like to see it!!!
  17. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    No thanks, I didn't have any trouble identifying this carrier/locker. But thanks anyway.
  18. K5Kell
    K5Kell Guest
    I wouldn't mind seeing that exploded view. Curiousity....
    -Kell-
  19. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    It is an open differential. You can tell because it has four pins. If it was a posi, it would have three pins. Thats the bad news, the good news is that only open diffs can have lockers installed. The carrier looks good and you can always add the Detoit later.
  20. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    sorry, I was wrong. I checked further and it is a locker, you can tell by the ring gear side with the bulge. Earlier post was right, you can see some of the internals.
