locker question
Discussion in 'OffRoad Design' started by snowcamo93, Dec 14, 2006.
  1. snowcamo93
    snowcamo93 Registered Member
    Nov 20, 2006
    7
    houston,tx
    i just got my first k5 and i was wanting to know if all 10 bolts are the same? ex.. will the locker out of a 94 10 bolt work in my 86 k5 10 bolt? in the rear or the front? just looking for a little advise.
    thanks
  2. mrk5
    Apr 20, 2004
    12,327
    1,031
    Northern Colorado
    Nope. After '87 or '88, the 10bolts were 30-spline axle shafts. Before that they are 28-spline.
    So the 94 should be 30-spline and your 86 28-spline.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    89 officially is the cut off date , but its not set in stone as to whether they finished the 28 splines off on the assembly line in early 89 or not .
  4. snowcamo93
    Nov 20, 2006
    7
    houston,tx
    thanks for all your help
  5. snowcamo93
    Nov 20, 2006
    7
    houston,tx
    what if i used the axles out of the 94 axles out of the 94 and put them in my 86 housing will the locker work then? see the reason for this is that the 94 axle has 4:56 gears abd my blazer has 3:73. but i want the blazer to be locked. is there any help?
